Member
harmzah
Message 1 of 7 (491 Views)
Creating file suitable for import as surface
491 Views, 6 Replies
02-06-2014 11:48 PM
Good day expert in house,I'm a neophyte civil guy. just got to prepare a profile view of an irrigation pipeline. I have created my alignments but need to import surfaces. All I have is an excel file containing coordinates and my z values. How do I create supportive file from this?
2. Woul anyone please give me a detailed explanation on how to calculate an invert level. I have vaues for my ground level. What else do I need and how do I go about it.
rkmcswain
Message 2 of 7 (462 Views)
Re: Creating file suitable for import as surface
02-07-2014 05:07 AM in reply to: harmzah
Do you mean that you have a CSV file with contents like this?
3121284.38296466,882181.92380207,128.0
3121277.99413417,882267.69275572,127.3
3121275.35443066,882375.23306138,126.5
3121272.51513517,882482.87407333,126.4
3121262.35874024,882580.84966059,126.4
3121233.10972356,883133.60346681,126.8
3121224.47339393,883240.46739907,127.2
3121238.46223642,882990.67567350,127.1
If so, then open C3D and create a new surface.
Go to the Defintion, right click on Point Files, and choose Add
Finish importing the file and your surface will be created.
Member
harmzah
Message 3 of 7 (443 Views)
02-08-2014 10:27 AM in reply to: rkmcswain
Thank you for your quick and perfect solution. The word CSV answered it all. Please help out on question two. Invert level of utility pipe at design stage. I have the values for my cover level. How do I determine the pipe invert level
tcorey
Message 4 of 7 (437 Views)
02-08-2014 10:50 AM in reply to: harmzah
Your second question is a little vague. Are you trying to input an existing pipe network or are you trying to create a new pipe network design? Just having the original ground elevations (of what, rim elevations?) doesn't mean you know where the invert is. Has it been surveyed?
What else you need is either depth to invert or depth to top of pipe plus pipe diameter. That needs to be surveyed.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Member
harmzah
Message 5 of 7 (389 Views)
02-12-2014 03:54 AM in reply to: tcorey
Thank you for highlighting the importance of survey. But the project is at the design stage and we are required to generate these values ahead of installation. Lets assume i decided to draw my pipe on a quick profile( free hand drawing), considering gradients at intervals, Would I deduct my pipe level from the existing ground level, or the proposed finished level.
tcorey
Message 6 of 7 (380 Views)
02-12-2014 09:15 AM in reply to: harmzah
That would be a question to ask your client or the contractor.
Tim Corey, Owner
Redding, CA
Member
harmzah
Message 7 of 7 (366 Views)
02-13-2014 06:36 PM in reply to: tcorey
Indeed you are correct. Thank you
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
