neilyj
Message 1 of 8 (922 Views)
Creating an Assembly Offset
922 Views, 7 Replies
09-19-2012 01:06 PM
I've just been looking at the Assemlby Offset but not sure what it is useful for - please can someone enlighten me???
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
mathewk
Message 2 of 8 (906 Views)
Re: Creating an Assembly Offset
09-19-2012 02:22 PM in reply to: neilyj
With assembly offset and ETW target
With normal assembly, same target.
The offset needs its own alignemtn AND profile.  As you can see, you are not limited to your corridor sections being perpendicular to the baseline alignment, instead they are perpendicular to the target alignment.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
jeff_rivers
Message 3 of 8 (903 Views)
09-19-2012 03:31 PM in reply to: mathewk
Very nice pictures, thanks for creating those.  What happens in the small gaps at the beginning and end of the offset region when you make a corridor FG surface?
Win 7E 64-bit, Intel i7, 12 GB
C3D 2012
mathewk
Message 4 of 8 (900 Views)
09-19-2012 03:35 PM in reply to: jeff_rivers
I'm not sure why I don't have more sections near those gaps, but any surface would just triangulate across those areas.  There's a chance you'd have to swap a few edges to make the TIN correct.
Matt Kolberg
neilyj
Message 5 of 8 (878 Views)
09-20-2012 12:56 AM in reply to: mathewk
Thanks for this - I've never really looked at assembly offsets before as never had any need...:smileyhappy:
neilyj
Joe-Bouza
Message 6 of 8 (861 Views)
09-20-2012 06:43 AM in reply to: neilyj
I don't know if this has been fixed in 12 or 13 but in 11 you are not able to extract a feature line from an offset assembly and maintain dynamic connection to the corridor.
Snip from my SR:
Thank you for your update. That is part of the issue. You seem to be creating feature lines (links) with the offset assembly. The issue is that program is not able to create the feature line. I hope this will be fixed in the near future. Unfortunately I have no information when.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Mentor
fcernst
Message 7 of 8 (809 Views)
11-13-2012 06:52 AM in reply to: mathewk
Please program Civil 3D to have the capability to recognize that the subassemblies that are outside of a transitioning alignment have to be oriented perpendicular to that transitioning alignment for correct surface triangulation.
Users now have to go through the extra work to set up an Offset Assembly, come up with a clever Profile scenario, (or a MarkedPoint configuration)  just to realize proper triangulation that should be occurring in the first place.
Then the user has to keep the above mentioned extra Corridor, Assembly, Profile or MarkedPoint,  overhead in mind for the duration of the project. This type of non-elegant overhead unnecessarily detracts from the good aspects of Civil 3D.
Super elevation axis of rotation is not supported with Offset Asemblies. Therefore, how does one get proper triangulation outside of the LaneSuperelevationAOR subassembly with superelevation?
Fred
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
mikeevans
Message 8 of 8 (799 Views)
11-13-2012 07:43 AM in reply to: jeff_rivers
These are probably due to the offset value between the channel line and the widening offset alignment being too small or zero, I get this a lot.
Instead of assembly offsets insert a different subassembly or you could use a conditional "Target found" subassembly in this region as I do.
If you then allow the two regions to overwrite each other by a small ammount or until they are perpendicular to the master alignment then you can erase the underlying subassemblies and you will have the gaps filled and ready for setting out (NB: a carefully positioned second conditional target found would also do this instead of edits).
Obviously you still need to provide a profile for the offset alignment but the outside edges will be correct.
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
