Civil 3D Forum
Creating an 3d alignment on a 3d surface?
9 REPLIES 9
Message 1 of 10
mrz999
5028 Views, 9 Replies
New to civil 3d?  Can I create an alignment on a surface so the alignment will value (follow) topo survey points on a surface.? My survey point are EX. elevation 600' to 700'.  When I create an aligment from a poly line our the aligment creation tool the alignment defautls to elevation 0'.  There for my feild stationing and CAD stationing is diffrent.   Any Ideas Thanks?
9 REPLIES 9
Message 2 of 10
dibr0804
in reply to: mrz999
Create a 3d polyline that runs through your points, then convert the polyline into a feature line, then create a profile from the feature. Or maybe you can just use the 3d polyline to get your profile without converting it to a feature line.
Message 3 of 10
WalterL
in reply to: mrz999
You can create a feature line (C3D 2012) from a polyline and have it add all the surface elevations to it, and then create an alignment from that.
Message 4 of 10
mrz999
in reply to: mrz999
WalterL
How do you create a alignment from a feature line? thanks
Message 5 of 10
SethHall
in reply to: mrz999
Alignments are only X Y objects, they do not have an elevation. If you have a surface created from the points, you can trace the points with an alignment, then sample the surface using the alignment creating a surface profile. Is this what you are looking to achieve?
Seth Hall
Product Owner
Model Builder
Message 6 of 10
AllenJessup
in reply to: mrz999
Alignments are 2D. You can create a Surface from the field points and then create a Profile from the Alignment and Surface. I think you can extract a Featureline from the Profile. If not you can create a Corridor with a single Assembly and extract a Featureline from that.
But that doesn't seem to address your need. You seem to want to run stationing along a 3D surface. I don't think that's possible in any program I've heard of.  In nearly 30 years of Surveying and Engineering, I've never heard of this being done.
Allen
Allen Jessup
CAD Manager - Designer
Message 7 of 10
Cadguru42
in reply to: mrz999
I've always wondered why a 3d polyline isn't used for an alignment and profile.  Seems like it would be easy to have one object that does both functions. It wouldn't be hard to program a way to view the 3dpolyline as a 2d line in plan view and a side view for a profie.  In the case of having a need for two profiles, just have another 3d polyline that has the same horizontal coordinates but the vertical is different.
Seems like then it would be easy to use a sweep (Is that the term? I'm used to 3ds Max's loft) of a road assembly section in order to get a corridor. This could also be done with basic, Autocad objects, which means no versioning problems and could be backwards compatible, not to mention easy for 3rd party applications to access the objects.
Of course, I could be completely wrong about my idea and that alignments have to be 2d for some reason I just don't know about.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Message 8 of 10
josephbouza5497
in reply to: mrz999
Um just a dumb civil engineer. I curious why you want a 3d alignment?
Message 9 of 10
n2itive
in reply to: mrz999
Hmm... so if you're using a 3d alignment and stationing how would someone in the field calculate a random distance or elevation from the plan&profile sheet? I know technology has come a long way but contractors still need to do some random dimensions or scaling every once in a while. If your alignment and stationing were 3d then your profile grid lines would be at random intervals based on the slope of the profile (or alignment in this case). The steeper the slope the closer the grid lines spacing would be.
I don't  think it's a question of why it's not possible (in a computer programming sense) but instead has to do more with common practices within the industry.
Infrastructure Design Suite 2014
Civil 3D 2013 sp2
Windows 7 x 64, 16 GB
Intel Xeon @ 2.80 GHz
NVIDIA Quadro K2000
Message 10 of 10
Cadguru42
in reply to: n2itive
Feature lines have the 2d length property as well as the 3d length property.  I don't know why a 3d polyline couldn't have the same properties since they are essentially the same thing.  The stationing would be based on the 2d length, so it'd be no different than it is today.  But, there could be the option to get 3d stationing if for some reason someone needed it for a physics calculation or some other reason. More options are better than none.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Rail Community
