Civil 3D Forum
Creating a surface from contours
4 REPLIES 4
272 Views, 4 Replies
Greetings,
I am trying to create a surface in C3D 2007 by using contours. However, after I create my surface, I try to add contours but the selection set says "none found." I listed the contours I am trying to use and they come up "AECC_CONTOUR."
What am I doing wrong? Or, is something else amiss?
Thanks in advance for anybody's help.
Scott
4 REPLIES 4
olsonscottm wrote:
> Greetings, I am trying to create a surface in C3D 2007 by using
> trying to use and they come up "AECC_CONTOUR." What am I doing wrong?
> Or, is something else amiss? Thanks in advance for anybody's help.
> Scott
Did you perhaps get the file from Land Desktop? Perhaps it's not
picking up on the contour objects.
Jason Hickey
Civil 3D 2007, SP3
Dell Precision M70
2 GIG RAM, 256 MB nVidia Quadro FX Go1400
Intel Centrino 2 gHz Processor
www.civil3d.com
Jason,
Thanks for the reply. After much head scratching and finally asking several people in the office, I have determined that what you said is correct. When I copied the contours in, I didn't actually get all of the information.
Thanks for the response.
Scott
Hi Scott,
Can you get the original Land Desktop DTM?
May be by a LandXML process, or through an Import of Land Desktop project
data.
As DTMs built from contours are inaccurate they should only be used as a
last resort.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5414266@discussion.autodesk.com...
Greetings,
"AECC_CONTOUR."
Scott
Laurie,
I was able to track down the original engineer and we worked out getting the DTM, which simplified the process exponentially.
Scott
Rail Community
