If you're getting contours crossing contours, I think you most likely have
some bad elevations, etc., in the objects.
For most projects, creating a surface from contours should be 'good enough'
to get the job done, just make a 'no display' style and use the contours you
received for display/plotting. It's far less than ideal of course, and as
Laurie suggested, it would be *best* to get the DTM or at least the DTM data
(breaklines and points) used to create the original surface.
"Matt W" wrote in message
news:5049176@discussion.autodesk.com...
I'm having one heck of a time with this one...
I work for an engineering firm. We get the survey information from one of
three places: The surveyor, the landscape architect or, God forbid, the
Architect (depending on where we are in the chain of command of any given
project). When we get the survey, 99.9% of the time we only get a DWG with
maybe AEC contours but mostly PLINES with a Z elevation. Getting the point
files or a DTM is next to impossible.
So, given everything that I've read to date regarding the no-no's of
creating a surface from contours only (point groups are better), what's the
BEST way to get a surface that represents the contours in the drawing?? My
first few attempts resulted in the contours crossing boundary lines and I
even had a few contours that crossed other contours!
Any input that anyone can give will be greatly appreciated.
Thanks in advance!
Matt W
"What am I gonna do with 40 subscriptions to Vibe?"
