Hi:
Coming back to after couple of years to Civil 3D world. A real simple question: I am trying to create a surface from a corridor properly. I tryed selecting the corridor open the Corridor Properties dialogue box and follow the instructions below:
Surface Tab
Click Create a Corridor Surface Buttom
Choose Links in Data Type context menu
Choose Daylight in Specify Code contex menu and press Plus buttom
Click check box in Add as a Breakline column
Click Apply and OK in the Corridor Properties dialogue box
After that, the surface is created but the details of the grades, gutter, curb and sidewalk are lost. How is possible to create the surface showing all the details? A hint: The sub assemblies of the corridor are based originally in polylines created by me.... it did work in version 2010, now is not working?
Please check the word document and let me know your comments
Rafael
To create a finished grade surface, use the "top" link code name, instead of "daylight".
If the subassemblies were created from your polylines, it is likely you do not have the proper link codes assigned. I suggest you re-create the assembly using the built-in subassemblies like LaneInsideSuperAOR, UrbanCurbandGutter, UrbanSidewalk. Each of these will have links called Datum and Top. Use one of these link to create your surface.
Optionally, use SubAssembly Composer to create the subassemblies and hardcode the link codes. This would be an option for an intermediate to advanced user.
