AutoCAD Civil 3D General
Active Member
Message 1 of 8 (1,163 Views)
Creating Surface From USGS NED Files
1163 Views, 7 Replies
04-15-2010 10:23 AM
I have been reading and researching the issue on how to create surface information from a USGS NED file. I have found some round-about ways that involve importing a .adf file from map3D and creating polyline object information. What I did was, created and new surface-> expanded that surface in the prospector window -> expanded the "Definition" tab -> right clicked "DEM Files" and selected add-> navigated to to my folder with the NED file in it and select the largest .adf file and imported that. It created a surface with contours just like if I had imported a USGS DEM file. However, I didn't check the coordinates, I assume they are off and would have to be properly adjusted. This seems a whole lot easier then some of the other explanations, unless I am missing something or if this method produces a totally incorrect surface. Anyone have insite on NED surfaces in Civil3D? Edited by: jakeamericus on Apr 15, 2010 5:29 PM
*neilw
Message 2 of 8 (1,163 Views)
Re: Creating Surface From USGS NED Files
04-15-2010 11:08 AM in reply to: jakeamericus
It sounds like you are using the proper workflow in that you are creating an
empty surface and then adding the DEM vs. creating the surface directly from
the DEM. Therefore, when you add the .adf file to your surface object you
should see an option to specify a coordinate system in the dialog. If your
DEM CS does not match the drawing CS, you will need to specify the DEM CS in
the dialogue. C3D should then reproject it to fit the drawing.
Active Member
Message 3 of 8 (1,163 Views)
04-15-2010 11:20 AM in reply to: jakeamericus
Thanks I'll give it a shot.
Active Member
Message 4 of 8 (1,163 Views)
04-15-2010 01:51 PM in reply to: jakeamericus
do you know what the coordinate input information is for NED files? I know these files are created with the NAD83 but when I select this option in the "Select Coordinate Zone" while creating a new surface in Civil3D I don't know what the "Available coordinate systems:" should be set at...also do you know if there are any issues with XFEFing surfaces created from a .adf file?
*neilw
Message 5 of 8 (1,163 Views)
04-15-2010 01:53 PM in reply to: jakeamericus
See my reply to your subsequent post regarding the CS. I don't know what
issues you have in mind with XREF's. The surface should behave as any other
C3D surface.
Active Member
Message 6 of 8 (1,163 Views)
04-16-2010 05:51 AM in reply to: jakeamericus
got it to work, I was using UTM NAD 83 but needed to use Lat/long 83 (LL83)...now, the surface is in to coordinates but was produced using meters, do you have any ideas how to convert elevations from meters to feet during the import of a .adf file?
Active Contributor
Message 7 of 8 (1,162 Views)
04-16-2010 07:36 AM in reply to: jakeamericus
1. Set the coordinate system in the drawing:
i usually start with a blank drawing, save it and then go to TOOLSPACE, Edit Drawing Settings Tab, right click and choose the correct CS under "Units and Zone".
2. Import the USGS file and it should covert it to the currents CS and units (feet) as set in the "Settings TAB" in the background without any additional steps.
A webcast series details the steps:
http://www.adskmedia.com/civilwebcasts/archive.php
"Competitive Road Design Series: Integrating Geospatial Data with AutoCAD Civil 3D"
New Member
nlthompson
Message 8 of 8 (753 Views)
09-05-2011 08:15 PM in reply to: jakeamericus
yeah, I had the same problem...how do you get meters to convert to feet as part of bringing in the .adf file?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
