AutoCAD Civil 3D General
New Member
Message 1 of 4 (220 Views)
Creating Points according to elevation
220 Views, 3 Replies
01-03-2013 04:51 AM
Hello all,
I have a number of 3D polylines that where exported from SDF previously created. They have numerous vertices, each one with a given elevation.
Could someone help me by tellling me how can i create/highlight the higher and/or lower point in each 3D polyline??
A different solution would be automatically breaking these polylines in slope changing points (i.e. high or low points).
I understand that i can create points according to slope or elevation, but it has to be done manually, each poly at a time, and by tipping numeric values that i am sure that a powerfull software (as Civil 3D is) is able to calculate using the drawing information.
Thank you very much in advance by your help.
Rui
Jeff_M
Message 2 of 4 (202 Views)
Re: Creating Points according to elevation
01-03-2013 05:56 AM in reply to: rbprata
Perhaps you will find THIS useful.
AllenJessup
Message 3 of 4 (195 Views)
01-03-2013 06:23 AM in reply to: rbprata
You could create points on the polyline then sort the point list by elevation.
New Member
Message 4 of 4 (155 Views)
01-04-2013 02:59 AM in reply to: Jeff_M
Dear Jeff,
indeed i found what you sent me very usefull...thank you very much
Best regards
Rui
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
