When creating FeatureLines, I wanted them to be e.g. Step Line 1, Step Line 2, Step Line 3 etc so I amended the name template to suit. I created multiple from objects and the naming convention worked. If I did features individually (as I wanted certain ones in certain sites) it worked for the first feature but reverrted back to the default Featureline name on subsequent entry to the dialog i.e. it had "forgotten" the template name just set.
Am I missing something to get this to work correctly or is this how it's supposed to work i.e. useless for individual feture line creation?? This also happens for gradings.
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by machadt. Go to Solution.
Hi Neil,
Please make sure that you do this change under the Settings tab -> Grading -> Commands folder-> right click on CreateFeatureLines (Edit Command Settings)... Default Name Format
Thanks for this - It's working now but it's a bit illogical in my opinion and not how it is implied to work in the Name Selection dialog
