It's almost impossible to respond to your post without the actual
dataset - hence the apparent silence.
If you can, post the zipped file here if under a meg or in Customer
Files if over. I'm sure someone will give it a crank.
Karl Fuls PLS
Autocad AEC Training and Consulting
Autodesk Discussion Group Facilitator
Endbringer42 wrote:
> Thanks for the help guys.
> Endbringer42 wrote:
>>I have been trying to get my cross sections ready for plotting. I
>>created a Group Plot Style that has the following settings:
>>Plot Section Views: By Columns
>>Max in Row: 2
>>Max in Column: 3
>>Start Corner: Lower Left
>>Align Sections About: Centerline
>>Column Space: 5
>>Row Space: 3
>>Cell Size: Uniform for all
>>Plot By: Plot by page
>>Section View Group Sheet Style: Plot Sheet Style
>>Gap between Pages: 4"
>>Settings for the Sheet Style, "Plot Sheet Style"
>>Page Layout: Cross Sections (Layout) (this is ARCH D size)
>>What I cannot get to work is getting 6 cross sections per sheet. I can
>>get the actual sections to show correctly, but it ends up creating 1
>>sheet with all the cross sections or 1 sheet per section. It changes
>>everytime I regen the screen. If I'm in a layout with a viewport to the
>>model space, the sheet changes. How in the world are you supposed to
>>get the sheets to quit changing all the time? This is extremely
>>annoying and the built in help is no help at all.
