Civil 3D Forum
Creating 3D poly from Alignment and Profile
10 REPLIES 10
Message 1 of 11
rui.viegas
832 Views, 10 Replies
I've been asked to create a 3D poly from a given alignment and profile.
The only way I know to do it, is to create a feature line using the "createfeaturelinefromalign" command and exploding it.
My problem is that the resulting 3D poly loses a lot of the "precision" the feature line had (how closely it followed the alignment).
So does anyone know of another way to create a 3D poly or of some method of maintaining the feature precision when exploding it?
Thanks in advance,
10 REPLIES 10
Message 2 of 11
jmayo-EE
in reply to: rui.viegas
I seem to get a better FL if I do not use the FL from alig command. Instead, edit the profile style to display the 3D Chain in Model views and explode that. Copy the result to the clipboard and use UNDO to get back to the live profile. Paste the result back into the file.
John Mayo
Message 3 of 11
jmayo-EE
in reply to: jmayo-EE
Also when you use the FL from Alig command what values do you set for the weeding. You can try to minimize the values for grade and distance and see if you get better results.
John Mayo
Message 4 of 11
rui.viegas
I played with the weeding values, and it definitely had an impact when creating the FT but after exploding it the results were always bad in terms of the 3D poly's precision.
Your solution for creating the 3D poly using the 3D chain was quite usefull and gave very acceptable results. Thank you.
I found one thing curious however, and did some tests and always ended up with the same results.
All 3D polys made by using the 3D chain didn't show the last meter of the alignment. it was easy to correct that but does this happens top you when you use the 3D chain method?
Again thanks for the help
Message 5 of 11
jmayo-EE
"All 3D polys made by using the 3D chain didn't show the last meter of the alignment"
Without seeing the data I would bet that the alignment is longer than the corresponding profiles. Make sure the profiles extend through the full alignment stationing or shorten the alignment.
John Mayo
Message 6 of 11
rui.viegas
Thought that as well but double checked the profile's lenght and it matched the alignment's lenght
I also tried to shorten the alignment's lenght about 10m without making any change to the profile, in order to guarantee that the profile's lenght was not the problem, and came out short the last meter.
The last test I made was to create a test file with a simple alignment and profile from stracth but alas that last meter still eluded me.
I'm currently using Civil 2011.
Message 7 of 11
jmayo-EE
Unless this profile is from a corridor surface that is not fully designed to the extents of the profile then a solution eludes me as well. Sry.
John Mayo
Message 8 of 11
AllenJessup
And if you want to increase the tessellation of the Chain. See [this] post.
Allen
Allen Jessup
Engineering Specialist / CAD Manager
Message 9 of 11
neilyj666
Can you expand on this a bit as I'm a little lost....
I've got the profile in model view (SW isometric) but i don't follow the next steps as when I explode the 3D chain it produces a block and when exploded again the elevations are way out
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 10 of 11
jmayo-EE
in reply to: neilyj666
Perhaps something changed in 2013? I get perfect 3d polys after explodoing twice. Perfect results from a surface and layout profile.
John Mayo
Message 11 of 11
AllenJessup
Neil
I've done this a few times and never had much of a problem. The only thing is that if the tessellation of the 3D Chain is off the stationing you will see some difference, especially in vertical curves, when comparing elevations at even stations. So increasing tessellation may help. But I don't know what you consider as way off.
Allen
Allen Jessup
Rail Community
