I am trying to create an assembly with a U channel (side ditch) that's top will follow the sidewalk it is next to but I need the profile of the U channel to be different than that of the roadway. Is there a way to create a custom subassembly part that will do this? Can I create a different allignment/profile for the bottom of the U channel that can then link to the other assembly?
The only other think I can think of is to use a dynamic block to add the U channel to my cross sections, but that will take a lot of time to do.
Any ideas?
Thanks in advance!
You shouldn't need a custom sub to do this. At least one of the OOTB daylight subs can have a ditch that is controlled by a profile. Check the help files for DaylightBasin, see if that will work for you.
