AutoCAD Civil 3D General
Joe-Bouza
Message 11 of 19 (361 Views)
Re: Create proposed profile from surface profile
02-14-2013 12:31 PM in reply to: Rainman1
are you sure you didn't miss step 3 ?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Distinguished Contributor
Message 12 of 19 (357 Views)
02-14-2013 01:03 PM in reply to: Joe-Bouza
I was picking the wrong profile to edit in Step 4......duh!!!! Sorry. However, this procedure will be very helpful when trying to match existing ground in design. Thank you very much again!!
Joe-Bouza
Message 13 of 19 (355 Views)
02-14-2013 01:06 PM in reply to: Rainman1
hth
Good luck
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Message 14 of 19 (222 Views)
10-11-2013 02:25 AM in reply to: Joe-Bouza
Joe, your method is quite ingenious, have a kudo, most of the posts i've read don't seem have any solution to this issue, it seems to be a quite challenging problem...............I had created a profile from file n followed your steps to create a layout profile from it bt one thing though, when i want to change the update mode of the new profile to dynamic in profile properties->profile data->update mode the tab is either blank or only has the static option...........is there anything i'm missing when it comes to setting a profile to either static or dynamic?     Thanks in advance
Joe-Bouza
Message 15 of 19 (214 Views)
10-11-2013 05:25 AM in reply to: Razzmatazz
Hi Razz, Thanks
Layout profiles are not dynamic by defintion thats why the box is greyed out. What exactly are you trying to accomplish?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Message 16 of 19 (178 Views)
10-26-2013 06:16 AM in reply to: Joe-Bouza
Hi Joe, sorry for the delay but what i was trying to accomplish was importing an existing ground profile from file as well as a finished ground profile from file into the same profile view and then have civil 3D recognize them as existing ground and finished  ground respectively when i'm generating the incremental station elevation difference report for setting out data.
Razz
Joe-Bouza
Message 17 of 19 (170 Views)
10-26-2013 10:39 AM in reply to: Razzmatazz
Hello Razz
If you ignore the eg surface dialog the report will give the data, no? I just named the profiles appropriately from profile properties
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Message 18 of 19 (160 Views)
10-27-2013 05:00 AM in reply to: Joe-Bouza
Thanks alot,  assigned the profiles their appropriate styles in profile styles i.e. design profile and EG ground respectively and was able to come up with the report. I was in doubt at first because i thought the profile style properties only affect the visual appearance of the profiles such as colour, thickness e.t.c as in the traditional autocad. So they are also reflected in the reports as EG and FG?
If you don't mind, could u please have a look at this thread about a best fit alignment and see what you come up with.
Thanks alot man, Cheers!
Joe-Bouza
Message 19 of 19 (134 Views)
10-28-2013 06:22 AM in reply to: Razzmatazz
I tried it too and couldn't get it to work. I dropped in, on the side a few random points of my own and it did work. You should open an SR
Sorry
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
