Civil 3D Forum
Create pipe network from multiple objects?
10 REPLIES 10
Message 1 of 11
rhdins
6267 Views, 10 Replies
Can I create a pipe network from multiple objects?
For example, I have 10 feature lines that I want to use to create one pipe network. Instead of creating 10 pipe networks one at a time, can I create one pipe network all at once?
Thanks.
10 REPLIES 10
Message 2 of 11
tcorey
in reply to: rhdins
You would need to join the feature lines into one first.
Use the Joinfeatures command.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 11
troma
in reply to: tcorey
That may not be possible, eg if the features aren't connected end-to-end but branching off in different directions, or not touching at all.
Another option is to create 10 networks, then merge them together.
Mark Green
Working on Civil 3D in Canada
Message 4 of 11
rhdins
in reply to: troma
The feature lines aren't connected.
That's what I've been doing, is creating multiple pipe networks, then merging them.  I would like to be able to select all 10 feature lines and create one pipe network.
Any other ideas?  Maybe it's just not possible?
Thanks.
Message 5 of 11
C3D_TomR
in reply to: rhdins
I like tcorey's suggestion. Add additional feature lines just to connect them for creating the network then joinfeatures. After you create the network from the single feature line, you can delete those dummy pipes from the network. Maybe mark the ones that need to be deleted with a magenta circle near the midpoint until the pipes are deleted from the new network.
Tom Richardson
Autodesk Certified Professional in Civil 3D for Infrastructure Design
Autodesk AEC Community Blog
Crossing the line with Civil 3D
Twitter | LinkedIn
Austin CAD User Group Resources
Blog | Discord | LinkedIn
Autodesk Group Network Leader
Message 6 of 11
dean_petersen
in reply to: rhdins
I have run into this too.
If you have a lot of 3D polylines to convert you can use Map3D to write them out as a .shp file first with Object data attacehd, then use the Insert Tab / Import dropdown / 'Import GIS Data' command to read that .shp file in as a pipe network. If you are carefull about the object data you can even assign different pipe sizes to all the pipes as it is created.
Explode the 3D polyiles to 3D line segments first. Then attach object data for Internal diameter, wall thickness and description that matches the pipes you want to use from your Parts List. Also use the Z1 and Z2 properties as elevation data in the .shp file. MapExport to a .shp file, then import it into C3D as GIS Data. It all ends up as one network.
It is a bit of extra to do, but if you have a large number of pipes it will be reasonably efficient. Smiley Very Happy
Message 7 of 11
Jeff_M
in reply to: dean_petersen
I prefer my solutionSmiley Wink
Message 8 of 11
dean_petersen
in reply to: Jeff_M
Yep. That is nice. What does it cost?
Message 9 of 11
lim.wendy
in reply to: rhdins
Hey Dean,
I've taken your idea and compile it into a video for better illustration. Smiley Happy
http://www.screencast.com/t/JM0KBtov6c
See also: http://docs.autodesk.com/CIV3D/2014/ENU/index.html?url=filesCUG/GUID-05A18F1A-ADAE-4103-9317-2F46A5C...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 10 of 11
Ntuthuko.
in reply to: Jeff_M
Hi Jeff
I've just used your Sincpac-C3D solution and the pipe creation process does not capture elevations from the surface, so all my pipes have zero grade. I could overcome this by converting my polylines to 3D polylines, I guess. My primary concern however is that when I select 'Apply Rules' on one of the created pipes I get an error about a macro not being able to run, and so the rules remain unapplied. Can you or anyone please help me with that?
All assistance is appreciated.
Ntuthuko
[EDIT]
My apologies. Converting polylines to 3D polylines not only solves the pipe grade problem but also enables the successful execution of the 'Apply Rules' command. Problem solved!
Ntuthuko
Message 11 of 11
drazen.galic
in reply to: Ntuthuko.
Hi Ntuthuko,
I saw several add-ins (like solution from Jeff_M -Sincpac), which correctly solve the problem of converting multiple Acad elements to Civil 3D pipe network. If you wish, take a look, to what we did (StudioARS - Urbano Visio). I am specially proud of one option, that we found a way to apply pipe and structure rules for the whole network at once (connected or not-connected). It is an option.
Rail Community
