Civil 3D Forum
Create grade from a corridor.
5 REPLIES 5
joantopo
463 Views, 5 Replies
Hi.
I want to create a grade (without object grade) using a corridor.
This is my assembly:
This only contains  the subassembly "DaylightBench" in the side right.
I have the alignment and profile. I have created the corridor.
red line= alignment
green line= feature line (code Intersecction) converted to polyline.
pink surface= surface (code TOP).
I have added a boundary for surface of type "add from polygon" and I have selected the closed polyline(green line).
However, the boundary seems doesn´t work.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
5 REPLIES 5
fcernst
in reply to: joantopo
Does the corridor extents as a boundary option work?
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
alegonb88
Puede ignorar este hecho y luego, utilizando una superficie tipo "Contours and Triangles", eliminar los triángulos de la superficie que generan estas extensiones de corredor indeseadas.
Al fin de cuentas, el corredor no sirve de nada, es un paso medio entre alineamientos/perfiles/ensambles y una superficie.
Saludos!
MikeEvansUK
Your options are:
1. Add 3d boundary directly to surface as outer boundary.
2. Add coortidor extents as boundary:
NB: In order to use the corridor extents boundary you will need at least two baselines in the corridor. These do not actually have to have any data within, so you can add annother baseline then rebuild and it should work correctly.
3. Manually select boundary using featureline
4. You can use surface build Max triangle length but by the looks of it your internal surface will dissapear.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
joantopo
Solved.
With only one subassembly, it´s not possible create a boundary as right way. The "corridor extents boundary" or "add polygon" don´t work.
Finally, I have added a new subassembly (lane) in my assembly.
subassembly lane in left side, with only width= 1 cm.
slope= 0%
I have created the surface corridor and boundary using two feature lines (intersection and "borde carril").
Then I have created the other surface using grade (create fill) using the feature line "borde carril".
Finally, I have created a new surface and I have pasted the others surfaces.
fcernst
With only one subassembly, it´s not possible create a boundary as right way...
This sounded knid of strange, so I tested an Assembly with just one DaylightBasin2 subaasembly attached to it. The corridor extents boundary option clipped the exterraneous TIN lines. See Below:
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
