AutoCAD Civil 3D General
*Expert Elite*
rkmcswain
Message 1 of 5 (719 Views)
Create feature line by snapping to cogo point "node"
719 Views, 4 Replies
10-07-2013 02:43 PM
I think this issue started with SP2. I don't remember having these issues in SP1 and earlier.
Can anyone verify?
  1. Create some COGO points at varying elevations.
  2. Start a new feature line.
  3. Use "node" object snap and pick your first cogo point
  4. It does not pick up the elevation of the point (it used to)
  5. Now draw feature line segments to a few more cogo points entering the elevation each time.
  6. It does not pick up the elevation of the point (it used to)
  7. Now switch to Arc mode and snap to a few more cogo points.
  8. It does correctly picks up the elevation of the cogo points (like it used to)
*Expert Elite*
tcorey
Message 2 of 5 (706 Views)
Re: Create feature line by snapping to cogo point "node"
10-07-2013 03:56 PM in reply to: rkmcswain
Randy, you're talking about Civil 3D 2013 with service pack 2? It works correclty for me.
Are you sure your point style has 3d geometry set to Use Point Elevation?
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
*Expert Elite*
rkmcswain
Message 3 of 5 (680 Views)
10-08-2013 04:13 AM in reply to: tcorey
Tim
(1) Yes, might help if I were to specify the version..... (2013 SP2)
(2) Yes, the points are "at elevation"
(3) This morning, it's working as expected. I should have waited before posting. Guess it was a fluke that needed a reboot to correct...?
Thanks!
Valued Mentor
hardin
Message 4 of 5 (543 Views)
02-03-2014 08:13 AM in reply to: rkmcswain
We had the same problem.
I found out that if you pick on the center of the COGO point snapping to NODE gives you an elevation of 0 (Zero).
If you snap to the outer portion of the COGO point node (nearer to the ends of the cross or outer portion of the circle or trianlge or however the point is defined) using the NODE osnap, it will give you the elevation of the COGO point.
So, in summary:
Snap to the middle of the COGO point yields an elevation of 0.
Snap to the outer portion of the COGO point will yield its elevation.
Also, for what it's worth, snapping to the INSERT of the text of the COGO point will also give the elevation, but it won't be on the X,Y point of the NODE of that point.
*Expert Elite*
tcorey
Message 5 of 5 (530 Views)
02-03-2014 02:30 PM in reply to: hardin
So, in summary:
I sure can't get that behavior. The only thing I can get is the point elevation if the point style is set to use point elevations and 0 if the point style is set to flatten to elevation 0. I would love to see a drawing in which you can get the behavior you describe...
Tim
Tim Corey, Owner
Redding, CA
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
