AutoCAD Civil 3D General
Member
ds1qmk
Message 1 of 7 (1,090 Views)
Create curb return profile
1090 Views, 6 Replies
02-28-2011 06:44 PM
Hi all
I try to make curb return profile without profile view like a intersect command.
I was make curb return alignment but I can not find profile command without profile view
I wonder someone advise to me.
Regard
*Expert Elite*
Jeff_M
Message 2 of 7 (1,079 Views)
Re: Create curb return profile
02-28-2011 09:38 PM in reply to: ds1qmk
Why not create the profile view? Just create it, assign elevations based on the range you will need, then draw the profile.
Jeff_M, also a frequent Swamper
Valued Mentor
gccdaemon
Message 3 of 7 (1,058 Views)
03-01-2011 05:56 AM in reply to: Jeff_M
You could also edit the alignment, then click pick sub-entity, then add Z elevations on the "Pass through points".
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Member
ds1qmk
Message 4 of 7 (1,021 Views)
03-02-2011 03:23 AM in reply to: Jeff_M
Thanks for your advise
Member
ds1qmk
Message 5 of 7 (1,020 Views)
03-02-2011 03:31 AM in reply to: gccdaemon
Is that possible?
In case of fixed line (I was convert polyline to alignment)
1. I was select edit alignment geometry
2.  Click alignment grid view
3. Click Sub-Entity editor (Blank alignment layout parameter is shown)
4. Choose alignment entity in grid view then alignment layout parameter box shown alignent.
5. Click Pass through point1 & 2 and modify end of number
    (212884.9529m,377135.6833m,0.0000m) to (212884.9529m,377135.6833m,32.0000m)
6. but Pass through point 1&2 number is not change
Do I miss something?
Valued Mentor
gccdaemon
Message 6 of 7 (1,008 Views)
03-02-2011 06:06 AM in reply to: ds1qmk
Don't do the grid view. If you're using 2011, do this:
1. Alignments>Edit Alignment Geometry>Pick the alignment
2. Pick Sub-Entity>Pick line or curve in the alignment
3. Click the "Sub-Entity Editor" Icon next to the "Pick Sub-Entity" is what will allow you to edit the Z value. Go to the geometry section and at the bottom you'll see Pass Through Point1, etc. From here is where you change the Z elevation.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
Valued Mentor
Ajilal.Vijayan
Message 7 of 7 (387 Views)
06-24-2013 07:35 AM in reply to: gccdaemon
I was trying the same steps to update the elevation ,but the values are not changing.
Its keep going back to 0.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
