I have created a 3D-image of 23 different drillholes, drawn as cylinders. The holes start at different elevation and finish at diferent elevation. Now I want to create a 3D surface of the actual rock surface. I've tried to draw polylines between the points and create a surface from that but the program complains about the lines being in different UCS.
How can I go about doing this?
Perhaps this will help, check out the article on page 28.
There are a couple of different ways you could do this. The simplest would be to set points at each xyz and create a surface from them. I would use point groups to make adding the correct points to each surface easier.
If you have the coordinate data and depth information you can create separate point files for each strata layer you need a surface for. You can then use User Defined properties, custom point formats and point group overrides to create the point groups needed for your surfaces.
The errors you are getting from your polylines are because they are extruded to the current ucs. To remove the extrusion, you can use the Mirror 3D command and select the object option.
