I'm currently using the "Pressure Pipe" app in Civil 3D. The thing is, I need to create pipes that are smaller than 100mm (that's the smallest pipe in the catalogue). Specifically, I need 50mm and 75mm diameter pipes, parts and accesories. How can I create them?
Thanks in advance.
Solved by BrianHailey. Go to Solution.
From Windows:
Start > All Programs > AutoCAD Civil 3D 2013 > Content Catalog Editor
Mike
Look for this file on your system (if you are using 2013, look in the appropriate location):
"C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx"
