Active Contributor
alegonb88
Message 1 of 4 (997 Views)
Create Pressure Pipe Parts
997 Views, 3 Replies
05-21-2013 02:39 PM
I'm currently using the "Pressure Pipe" app in Civil 3D. The thing is, I need to create pipes that are smaller than 100mm (that's the smallest pipe in the catalogue). Specifically, I need 50mm and 75mm diameter pipes, parts and accesories. How can I create them?
Thanks in advance.
odoshi
Message 2 of 4 (982 Views)
Re: Create Pressure Pipe Parts
05-21-2013 06:45 PM in reply to: alegonb88
From Windows:
Start > All Programs > AutoCAD Civil 3D 2013 > Content Catalog Editor
Mike
www.civil3d.guru
Rockin' Civil 3D 2015 on a 13-inch MacBook Air | Intel i5 | 4GB RAM | 128GB SSD | Intel HD5000
BrianHailey
Message 3 of 4 (968 Views)
05-21-2013 08:18 PM in reply to: alegonb88
Look for this file on your system (if you are using 2013, look in the appropriate location):
"C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\Sample\Civil 3D API\Part Publishing Wizard\PartPublishingWizardUsersGuide.docx"
Active Contributor
alegonb88
Message 4 of 4 (953 Views)
05-22-2013 07:55 AM in reply to: BrianHailey
Funny the fact that its a WORD document! Perfect, looks like it isn't so simple but I should be able to create the parts I want from now on, thank you very much Brian.
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
