I have a feature line arc, 2 points with elevations.
I want to add a PI on either side of the arc, when I click insert pi, I cant place outside the line.
When i create a new Feature line and JOINFEATURES. I Crash.
Anyone Else experience the Joinfeatures crash?
Anyone have a solution to my issue?
I use join features everyday w/o issue.
Make sure the object you want to join to a feature line is either a 3dpoly or a 2dpoly.
In either case the vertex where the join occurs must have identical Z values on both objects for the join to work.
If you still have issue post a simple file with just the feature line and the objects you want joined.
John Mayo
But is there a way to just add a pi after the end?
Mark Green
Working on Civil 3D in Canada
Troma is correct. You can only add a PI inside the fline's start and endpoints. Also note his Extend comment. Extend works great. Sometimes you do want to maintain the FLine endpoint and add another arc. If I had to do this my workflow would be,
1. Draw an arc (or pline or 3dpline) from the endpoint of the original featureline by typing A into the command line and using osnaps (onsapz=0) to insure the arc is created at the FLine endpoint elevation.
2. Type PE into the command line to convert the arc into a pline.
3. Use FLine Join.
There is no need to convert plines or 3dplines to feature lines prior to FLine joining IF the meet at a common z value. I use this procedure often and never have crash issues.
John Mayo
Mark Green
