Civil 3D Forum
Create Grid in Model space
14 REPLIES 14
Message 1 of 15
jamesbarnett
1713 Views, 14 Replies
I am using  Civil3D 2012 and I am trying to create a 50'x50' grid in model space that automatically populates the N & E. Can anyone point me in the right direction?
AutoCAD Civil 3D 2022
14 REPLIES 14
Message 2 of 15
dgordon
in reply to: jamesbarnett
Cogo points can be populated based on a 50 x 50 grid and have a label style that just shows northing and easting.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Message 3 of 15
jamesbarnett
in reply to: dgordon
I'm not wanting to create points though. I just need the lat long lines and an annotation. Carlson has the command dgrid, but I'm not sure how to do it in Civil3D.
Message 4 of 15
AllenJessup
Use the MAPLAYOUTREFERENCESYSTEM to create the grid in a layout. Then use CHSPACE to move it to Modelspace.
Allen Jessup
CAD Manager - Designer
Message 5 of 15
sboon
in reply to: AllenJessup
You can set up a Note label style to display two lines and a coordinate at the intersection.  You can also create a dynamic block to do the same thing.
Steve
Expert Elite Alumnus
Message 6 of 15
jamesbarnett
I get this error
c:\program files\autodesk\autocad civil 3d 2012\acmapgridsystem.arx cannot find
a procedure that it needs.
Unknown command "MAPLAYOUTREFERENCESYSTEM"
Message 7 of 15
jamesbarnett
in reply to: sboon
Steve,
I figured out the note, but I can't seem to make it offset a specified distance. I tried to use the array, but I can't figure out how to make the thing work.
Message 8 of 15
AllenJessup
Have you installed SP1?
Allen Jessup
Message 9 of 15
jamesbarnett
The only sp update I get is for SP 2.1
Message 10 of 15
jamesbarnett
After updating to SP 2.1 the mapreference works great!
Thanks guys now I have 2 options on performing the same task. If I could just get the note to offset at a specified distance that would speed up that option.
Message 11 of 15
AllenJessup
Glad it worked for you. That was the solution on the one and only post I found about that error message. I would have gotten back sooner, but I had an equipment malfunction - I knocked my Trackball Explorer off the desk and broke an internal plastic part. Krazy glue fixed that but then a pin broke off the circuit board when I tried to reseat the ribbon cable. Oh Well!! Smiley Sad
Allen Jessup
Message 12 of 15
AllenJessup
I just found this. LAYOUTGRIDADD.
It doesn't label the coordinates. But it creates a grid in MS that can be adjusted in Properties or gripped and dragged to enlarge or minimize. You could label it with a Note Style.
Allen Jessup
Message 13 of 15
troma
Cool!
Also, can I say, very random!
Mark Green
Working on Civil 3D in Canada
Message 14 of 15
AllenJessup
in reply to: troma
Yes. You have to adjust the way the grid compiles and insert it or move it to an even intersection. This is what happens when you have Autocomplete on. You see a command and wonder what that does. Next thing you know you're in OZ running from the flying monkeys!!
Allen Jessup
Message 15 of 15
troma
Just make sure you have the right subassembly for that yellow-brick road.
Mark Green
Rail Community
