I'm hoping someone can help me with a system problem. I keep crashing, I went through this before and though it was resolved by changing my OS to windows 7 and upgrading my video card. It seemed ok for awhile and now its crashing and getting hung up when I pan. We through another 8 gigs of ram in it and it didn't help. It will hang for about 30 - 60 seconds not only in Civil 3D but the entire system. A service pack update was installed but it didnt' help either.
I have attached my specs and as far as I can tell my hardware is adequate... any suggestions would be appreciated!
Thanks!
What version and Service Pack of Civil 3D?
All drawings or certain drawings?
Does it have the same lag using the OOTB C3D user profiles?
Has the Temp folder been cleaned out recently?
C:\Users\username\AppData\Local\Temp\
Jay....
-I am using 2014 SP2
-All Drawings
-I'm not sure about the OOTB profiles, I haven't customized anything so I believe that's what I'm using???
-Have never cleaned the Temp folder..will do it now!
rkmcswain.....
- I searched through all the Search paths, file an,es and locations in Options, everything is local. We have a server where our drawings are stored but we have single users licenses.
- I tried to disable hardware acceleration but it is grayed out so I'm trying to see how or if I can in my AMP Firepro settings. I fee like I did this a while back to help resolve issues but it may have been prior to my 2nd video card upgrade...
Thanks so much for you help!
Sorry for the issues you are having.
Please make sure you are not running IE Compatibility mode. Try pressing the F12 key to check.
Also check and make sure that you are not blocking java scripts from addthis .com and autodesk.com.
Discussion_Admin
