sboon
Message 11 of 13 (148 Views)
Re: Crash on publishing to PDF
06-21-2013 08:53 AM in reply to: IanMcClain
DwgToPDF is the old one.  I believe that it was created by Autodesk and has never been updated.  The Publish command apparently is newer, or at least operates differently.  I have Adobe Acrobat installed, so I can print using their current version and do edits etc. but with images I sometimes have to use the old DwgToPDF also.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Valued Mentor
IanMcClain
Message 12 of 13 (143 Views)
06-21-2013 09:00 AM in reply to: sboon
Hmm, I was not aware there was a difference. Typically I use the publish command with layouts specified to use the named plotter, which I have set to DWGtoPDF. Apparantly I've always been using the old driver. It's never given me problems. I have tried adobe's driver, but ran into issues. DWGtoPDF has been solid for me.
-Ian McClain
(running C3D 2012 sp4, Win7 64bit, 8GB)
Active Member
durkie
Message 13 of 13 (134 Views)
06-22-2013 03:45 AM in reply to: IanMcClain
I have published in background turned off but I still didn't get any more usefull error message I think the file is just corrupt
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
