Is there a way to determine the number of styles in a drawing?
Allen
C3D 2010
Dell M6500, Win 7 Pro, 8GB RAM
Allen Jessup
CAD Manager - Designer
Solved by Alfred.NESWADBA. Go to Solution.
AFAIK not with 2010 (without dev).
With Civil3D2012 you have a command _PURGESTYLES that shows a number (of purgeable) styles plus copy&paste of the list is supported. Maybe this is a help.
- alfred -
Thanks. I'll give it a try.
Allen
Allen Jessup
_PURGESTYLES gives me 552 styles. So I'll go with that for now. Thanks.
Allen
Allen Jessup
It looks like there are about 70 unpurgable standard styles that won't show in that list. But it's a good start.
Allen
Allen Jessup
Hi Allen,
sorry, I have never did a check of this number. And as the count is for purgeable styles then the "Standard"-styles will not be counted within that group.
I find it interesting how you got the number 70 that fast - without having an option to count anything in another way yet 😉
- alfred -
Hello Alfred,
I used the old manual guesstimate method. I started a drawing with no template then used the purgestyles command. After that I'm left with a Standard style for each item that uses a style. I expanded each item in the prospector and counted how many times I saw Styles. I got just under 70 and rounded up.
Thanks for the help!
Allen
Allen Jessup
I need to give an estimate of the time to revise them.
Allen
Allen Jessup
The purge command only gives you the unused styles, there are styles embedded in the command settings that are considered "used" styles and will not show up in that list that represent a significant percentage of the total styles. If you have a fully customized template you could be looking at missing out on several hundred styles.
I, too, am looking for a way to count the styles as part of some purge testing I'm doing.
Mike,
Thanks for all the suggestions. Hopefully they will help someone searching on this topic in the future. In my case the need has come and gone. Project bid, accepted and completed. I was asked to create a metric template that mirrored a clients imperial template so I needed an idea of how many styles I would need to edit.
Allen
Allen Jessup
