Active Member
thisismyid
Message 1 of 5 (216 Views)
Corridors created by the junction tool - set up
216 Views, 4 Replies
10-15-2012 05:45 AM
Is there a way to change the default Style Set that is used by the tool?
I don't want [All Codes] to be used, and since I created a style for the project I'd want to be able to use it when creating corrridor using the tool.
Toolspace Settings seem not to have relevant option.
Any clues?
==== i7 @3.4GHz ==== 8GB @666MHz ==== ATI/AMD @675MHz ==== win7 x64 ====
tcorey
Message 2 of 5 (195 Views)
Re: Corridors created by the junction tool - set up
10-15-2012 11:18 AM in reply to: thisismyid
I'm not sure what you mean by Junction Tool, unless you mean Intersection.
If that's the case, the Intersection tool uses the default Code Set Style you have set by going to Settings tab of Toolspace, find Corridor, right click and select Edit Feature Settings. Set the default code set style under Default Styles.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Member
thisismyid
Message 3 of 5 (182 Views)
sRe: Corridors created by the junction tool - set up
10-15-2012 10:06 PM in reply to: tcorey
Yes i mean Intersection.
I changed settings for both corridor, and simple corridor, but when I "Rrecreate Corridor Regions" the tool still uses [ALL Codes]  :smileyfrustrated:
tcorey
Message 4 of 5 (159 Views)
Re: sRe: Corridors created by the junction tool - set up
10-16-2012 10:02 AM in reply to: thisismyid
There is no Simple Corridor at the level I am referencing. Sounds like you're drilling down to Corridor --> Commands --> Create Corridor and Create Simple Corridor. Please re-read my previous post and go to Feature Settings for Corridor at the first Corridor level of Settings tab.
Tim Corey, Owner
Redding, CA
Active Member
thisismyid
Message 5 of 5 (149 Views)
10-17-2012 02:10 AM in reply to: tcorey
Thanks Tim-
Managed to make it work
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
