Civil 3D Forum
Corridors created by the junction tool - set up
4 REPLIES 4
thisismyid
393 Views, 4 Replies
Is there a way to change the default Style Set that is used by the tool?
I don't want [All Codes] to be used, and since I created a style for the project I'd want to be able to use it when creating corrridor using the tool.
Toolspace Settings seem not to have relevant option.
Any clues?
==== i7 @3.4GHz ==== 8GB @666MHz ==== ATI/AMD @675MHz ==== win7 x64 ====
Tags (2)
4 REPLIES 4
tcorey
in reply to: thisismyid
I'm not sure what you mean by Junction Tool, unless you mean Intersection.
If that's the case, the Intersection tool uses the default Code Set Style you have set by going to Settings tab of Toolspace, find Corridor, right click and select Edit Feature Settings. Set the default code set style under Default Styles.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
thisismyid
in reply to: tcorey
Yes i mean Intersection.
I changed settings for both corridor, and simple corridor, but when I "Rrecreate Corridor Regions" the tool still uses [ALL Codes]  Smiley Frustrated
tcorey
There is no Simple Corridor at the level I am referencing. Sounds like you're drilling down to Corridor --> Commands --> Create Corridor and Create Simple Corridor. Please re-read my previous post and go to Feature Settings for Corridor at the first Corridor level of Settings tab.
Tim Corey
Redding, CA
thisismyid
in reply to: tcorey
Thanks Tim-
Managed to make it work
Rail Community
