I've read that it is possible to "hand draft" small complex areas that a corridor cannot handle easily.
I have an intersection in an old neighborhood that is constrained by retaining walls, buildings, and so on. In this I have to fit in current ADA ramps. Due to constrained space I will have to get creative in my elevations and layouts.
What would be a good workflow for a special situation like this? Ideally, I'd like to somehow integrate it with the corridor.
Thanks.
In a similar situation I used a corridor to build the paved surface, and then extracted the edge of pavement featurelines. From there I used the stepped offset, and other featureline editing tools to build the curbs, sidewalks, etc.
The Elevation by Reference tools on the Modify panel of the Ribbon are particularly useful for this type of work.
@sboon wrote:In a similar situation I used a corridor to build the paved surface, and then extracted the edge of pavement featurelines. From there I used the stepped offset, and other featureline editing tools to build the curbs, sidewalks, etc.
Considering that ADA ramps are on curn returns, does this work within intersections as well? I am presuming so.
I've attached a drawing with a couple of examples. The method that worked best for me:
"Ideally, I'd like to somehow integrate it with the corridor."
Split and Add a Region to the Curb Return baseline of your Corridor that spans the ADA Ramp stationing and use an Assembly for that Region that will target the ADA Ramp plan geometry.
This will be 100% dynamic for you.
Excellent suggestions. Thanks.
One additional question: Will this work if the ADA ramp is not radial or perpendicular to the curb? On odd angle, in other words.
(I ended up getting involved in other aspects of the project over the weekend, and have only had a chance to lightly touch on this so far.)
