Here's a good one for you all. I've created two corridors that run parallel to an alignment. The two corridors are widenings on a ramp. In plan view, the corridors display correctly, but when I pull section views along the alignment, one of the corridors work correcly, the other mirrors itself over the control line. Please see the attached pictures. I think the problem is that the two alignments I've created the corridors on are running in opposite directions. Due to the geometry of the site, this needs to be configured this way. Any help is greatly appreciated.
Thank you in advance.
-Kevin
Solved by tcorey. Go to Solution.
How about if you make the two alignments baselines in one corridor? Does that fix the issue?
