Still trying to figure out intersections. I split the region of my corridor for the intersection but the corridor is still pulling the surface in between the region split. How do I keep the surface from doing this without manually adjusting the surface?
Thanks.
You don't want to remove the surface at the intersection. Instead you'll want to build the corridor baselines and regions within that area, so that they are added to the corridor surface.
Just to clarify - are you building one corridor with the through roads and the intersection, or are you trying to create a separate corridor for the intersection only?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
