Civil 3D Forum
Corridors Surfaces and Intersections
5 REPLIES 5
348 Views, 5 Replies
I've created a T intersection and have created the surface for the T corridor and the entering side road. The surfaces appear correct. When I create a surface for the main road, which has been split into two regions, the surface goes thru the T corridor. How do I create a surface that simply goes up to the T intersection and picks up again after the T intersection?
5 REPLIES 5
troma
There may be a better way, but you can add a Hide boundary to your surface.
Mark Green
Working on Civil 3D in Canada
Thanks, that does work, but I would still like to do it correctly.
Jeff_M
I would've put everything in one coridor.
You could create a third surface and paste in the main road then the intersection surfaces.
in reply to: Jeff_M
Thanks. I thought about that approach also and will give it a try. Again, seems like a workaround.
fcernst
It seems like a workaround because you are making it so. During intersection creation choose to add the intersection to one corridor that consists of the two roads as suggested.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Rail Community
