Civil 3D Forum
Corridor
14 REPLIES 14
Message 1 of 15
Ed-Hovsepyan
1022 Views, 14 Replies
Corridor
Hi
I have a corridor with  intersection.The intersection isn't  90 degrees.
Can I cut corridor with(for example) 45 degrees???
Help 🙂
14 REPLIES 14
Message 2 of 15
in reply to: Ed-Hovsepyan
Yes, certainly.
Message 3 of 15
Ed-Hovsepyan
How???
Message 4 of 15
Ed-Hovsepyan
If not secret )))
Message 5 of 15
sboon
This thread might be useful.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 6 of 15
Ed-Hovsepyan
in reply to: sboon
I have 2 Corridors, and they intersect with eath other. Please to see on picture ................
Message 7 of 15
MikeEvansUK
You will need to model each corridor to tie together, alignments tying up to each other and gaps where they join etc. or create a combined corridor model.
This will need multiple subassemblies and baselines with gaps where they join.
If you google for civil 3d junctions this should get you started.
junction creation
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 8 of 15
Ed-Hovsepyan
in reply to: MikeEvansUK
Thank you for a good advise,It would be useful . But I create corridors by hand.
Message 9 of 15
MikeEvansUK
I always manually create junctions but the work flow is the same as what the Junction/intersection tool creates.
If you look at a tutorial for the tool then look at what it produces this will give you an idea as to how to stitch the model together.
Mike Evans
Message 10 of 15
fcernst
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 11 of 15
Joe-Bouza
in reply to: fcernst
Nice! Is that only an Int marker or is the a true intersection model?
Joe Bouza
Message 12 of 15
fcernst
in reply to: Joe-Bouza
Yes, all of that Corridor you see is  one Corridor created by the Wizard:
Wizard created for me:
1 Corridor
6 Alignments and Profiles
7 Regions
2 Widenings with Line-Curve-Line transitioning
I completed this using the Wizard in 42.8 seconds from start to finish. Probably could get a lot faster if I practiced more.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 13 of 15
Ed-Hovsepyan
I will try.  In your picture is that what I need )
Message 14 of 15
Ed-Hovsepyan
In your picture is that what I nee.I will try!
Message 15 of 15
Ed-Hovsepyan
now I have 2 unsolved question
1 When my 2 alignments didn't intersect with each other I can't create by automat system of civil 3d .................................
2 When there is  a 1 corridor , and I must CUT it  with XX degree................Smiley Mad
Rail Community
