Hello group,
I'm trying to locate directions for creating a corridor using existing points brought into Civil 3D. I want to have a corridor created that will tie to my edge of pavement shots, used to creat exisiting conditions for a set of plans to create new shoulders and ditches on. Anyone know of a way this can be done or did I simply miss something basic?
Thanks!
@dchw wrote:Hello group,
Thanks!
Sounds like you just need to make a surface of your shots. Then you can make an alignment and surface profile of the EOP and create a corridor for your new shoulders and ditches. Make the corridor use the alignment and profile of the existing EOP and you should be good to go.
