I created a new composit surface from a number of other surfaces together via paste surface.
When I go to choose this surface as a target for my corridor it doesn't appear in the list of surfaces. All other surfaces appear. I have audited, and closed and reopened C3D 2010, but it has not fixed the problem.
Anyone know why this is happening and what I can do to fix it?
Solved by areese9779. Go to Solution.
Is your corridor a part of one of the surfaces that is in the composite surface? That would prevent targeting the surface.
In a way it was. The corridor was targeting the existing surface still. The existing surface was included in the composite surface. To fix it, I changed the target surface to none and closed the corridor properties dialog. When I reopened the dialog box the composite surface appeared.
Erik
