AutoCAD Civil 3D General
Nik-D
Message 1 of 3 (263 Views)
Accepted Solution
Corridor surface won't form correctly
263 Views, 2 Replies
07-28-2013 08:12 AM
Hi all,
I have been banging my head against a wall for a while now trying to get this corridor surface to form properly. It wont seem to triangulate properly from where I have copied the intersection into the East-West corridor. Any suggestions would be appreciated.
Cheers
NIk
*Expert Elite*
BrianHailey
Message 2 of 3 (247 Views)
Re: Corridor surface won't form correctly
07-28-2013 10:37 AM in reply to: Nik-D
In the following image, I've issolated one baseline.
The issue you are having is you are adding featurelines from this baseline and they will connect from one side to the next. If you need to add featurelines, you'll need to break this up into two baselines (same for the other cross street).
For your corridor, you can get away with just adding the top links and no featurelines. If you corridor has an irregular cross section at some point (such as a widening or narrowing) then you'll need to add in the featurelines.
HERE is your drawing the way I would do it.
Nik-D
Message 3 of 3 (238 Views)
07-28-2013 11:30 AM in reply to: Nik-D
Cheers I see whay you have done. I did not realise that by putting the TOP link it puts in the top links of all the subassembly parts. I thought yu had to individually specify which bits you wanted. This has made my life a lot easier.
Cheers
Nik
You are not logged in.
Announcements
Need installation help?
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
