Civil 3D Forum
Corridor surface strangeness...
6 REPLIES 6
688 Views, 6 Replies
Hi everyone. I have a realtively simple corridor runnning through a site that is somposed of an alignment, profile, and fairly simple assembly with two lanes of pavement, curb and gutter, a link for shoulder, and a daylight. As the corridor runs along my horizontal curves it appears to do some strange cross tinning in the corridor surface. The edges of pavement do target some feature lines, but even if I remove those and just target a 2D polyline I get the same strangeness. See images attached. Any idea what Im doing wrong here? Thanks.
assembly.jpgobject viewer
-Tristan
6 REPLIES 6
sboon
The images in your post are distorted in my view, makes it hard to see what's going on.  Can you upload the drawing so that we can take a look at it?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: sboon
Hi Steve,
Unfortunately I cannot upload the file as it is confidential. However, I've been able to reduce the artificating that occurs along the curb by increasing the frequency to 1', but its making for a pretty dense and heavy model.
tyronebk
As Steve said it is tough to figure out what's going on, but have you tried adding the curb (lip, face, top, back) feature lines to the corridor surface? This often helps to control TIN lines that cross unexpectedly.
in reply to: tyronebk
Thanks Tyrone, that did the trick. However, now Im having a new issue...My corridor is broken into two regions, and the second region is not generating a surface like the first region. It initially was working, but at some point last night the contours for the surface dissappeared. Now if I look at the corridor in Object Viewer everyting looks OK, but the surface is not there. Im guessing at some point it was user error on my part. I've tried recreating the corridor surface from scratch and still no luck. Thanks.
wfberry
in reply to: sboon
Steve:
I don't think this will help any, but when I "opened image in a new tab" the distortion went away.  I haven't seen this before.
Bill
tyronebk
Without seeing the drawing I can only speculate on a few potential problems: - a boundary is cropping off the surface in the second region (but if you recreated the surface and see the same result this likely isn't it) - a link code was removed from a subassembly that was being used to create the surface
Rail Community
