Civil 3D Forum
Corridor section points report problem
5 REPLIES 5
ericdaniel
1919 Views, 5 Replies
I have a problem with the corridor section points report on Civil 3d 2014. It only presents the first station on the corridor. Attached image.
Thanks in advance for your help.
Eric
Tags (2)
5 REPLIES 5
BrianHailey
in reply to: ericdaniel
I just tried it in one of the tutorial files and it seems to work just fine there. Your stations seem to be at an odd number, do you have corridor sections at those stations?
Just to test it out, I tried it again in the same tutorial file and I had it start at station 0+01 and incriment 25'. No data at all. I would bet that's the issue.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Jeff_M
in reply to: BrianHailey
+1
HERE is a link to someone's workaround to the issue, perhaps it will work for the OP.
ericdaniel
Yes, that was the issue, the starting station of the corridor, once I changed it worked fine.
Eric
BANI_INDICA
yes the corridor beginning station is the point ... if you applied the frequency interval 5 the corridor considers every 5m interval from the beginning station which would lacking the information for the corridor section view report  where as the corridor section report considers at every 5m distance but not from the beginning station value !
anthony.nr
please select corridor properties & in parameters change the frequency (lesser) & generate the report.
thanks,
Anthony
Civil 3D 2011, 64bit
Dell t1600 Win7 Pro.
Xeon 3.3GHz
8GB RAM
Rail Community
