AutoCAD Civil 3D General
Message 1 of 7 (358 Views)
Corridor missing triangles error
358 Views, 6 Replies
02-07-2013 08:05 AM
I'm doing a small design for a footway/cycleway across an embankment behind an existing retaining wall with a tie-in to an existing car park.
  • H-alignment done (LHS edge alignment, chainages working from west to east)
  • H-alignment target extents to retaining wall
  • V-alignment done, with target to RHS offset design levels beyond crest and into car park
  • Combined surface created by pasting existing ground and finished top surface (shown in contours).
  • Some anomalies corrected by swapping edges in the EG surface.
As can be seen, I appear to be missing triangles from the design corridor.
I'd be very grateful for any advice about what I should experiment with in order to improve the corridor model. This will improve the accuracy of the earthworks calculations. Thanks in advance.
Joe-Bouza
Message 2 of 7 (333 Views)
Re: Corridor missing triangles error
02-07-2013 04:38 PM in reply to: trevj
Thats some frequency :smileywink:
Have you verified all targets for all regions?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
sboon
Message 3 of 7 (317 Views)
02-07-2013 06:51 PM in reply to: trevj
It looks like you might have a boundary problem that is causing triangles to be deleted.  How is the surface boundary defined?
Message 4 of 7 (300 Views)
02-08-2013 01:44 AM in reply to: sboon
Thanks for the swift replies.
Thanks, yes, I could reduce the frequency, but it's only 50m long and I wasn't confident with the 1m frequency. I really need to compare surfaces for different frequencies (probably finished contours would do it).
Yes, but I've not removed all the region definitions and retargeted from scratch. I'm not sure if it's correctly designed or not. Maybe these further screengrabs will be informative.
The surface is created from the corridor, with no additional edit operations listed in the surface properties.
(The remaining Edit operations are Yes, except 'Use simplify'.) Some of the missing triangles cross region boundaries, but some are within single regions, with correct triangles either side running to the start/finish of the region(s).
Message 5 of 7 (258 Views)
02-15-2013 10:05 AM in reply to: Joe-Bouza
Do you have any more pointers on this, please? Thanks.
sboon
Message 6 of 7 (254 Views)
02-15-2013 10:21 AM in reply to: trevj
To clarify my original question.  Is the surface boundary defined in the corridor by polygon, by featurelines or by corridor shrinkwrap?
Message 7 of 7 (209 Views)
02-21-2013 03:20 AM in reply to: sboon
The boundary was undefined! I've added it as corridor shrinkwrap and it now seems to be sorted! Thanks so much :smileyhappy:
You are not logged in.
Ask the Community
Civil 3D Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for AutoCAD Civil 3D helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Civil 3D
Twitter
Facebook
Blogs
