I'm doing a small design for a footway/cycleway across an embankment behind an existing retaining wall with a tie-in to an existing car park.
As can be seen, I appear to be missing triangles from the design corridor.
I'd be very grateful for any advice about what I should experiment with in order to improve the corridor model. This will improve the accuracy of the earthworks calculations. Thanks in advance.
Solved by sboon. Go to Solution.
Thats some frequency
Have you verified all targets for all regions?
Your Name
Your Name
It looks like you might have a boundary problem that is causing triangles to be deleted. How is the surface boundary defined?
Thanks for the swift replies.
@Joe-Bouza wrote:Thats some frequency
Thanks, yes, I could reduce the frequency, but it's only 50m long and I wasn't confident with the 1m frequency. I really need to compare surfaces for different frequencies (probably finished contours would do it).
Yes, but I've not removed all the region definitions and retargeted from scratch. I'm not sure if it's correctly designed or not. Maybe these further screengrabs will be informative.
@sboon wrote:It looks like you might have a boundary problem that is causing triangles to be deleted. How is the surface boundary defined?
The surface is created from the corridor, with no additional edit operations listed in the surface properties.
(The remaining Edit operations are Yes, except 'Use simplify'.) Some of the missing triangles cross region boundaries, but some are within single regions, with correct triangles either side running to the start/finish of the region(s).
To clarify my original question. Is the surface boundary defined in the corridor by polygon, by featurelines or by corridor shrinkwrap?
