Maybe someone can help with this this one...
How do i get the feature lines in my corridor to change their style based on the code set style selected??
Whats the point of defining featureline styles in the code set style if they dont change in the corridor? They only get used when you first create the corridor?
Is there something I am missing or is this the intended workflow?
Kapanther
Don't you love the coy responses from the Resellers?
Pertaining to your problem: Yes, this is a dumb and frustrating aspect of the Code Set implementation into Corridors. It makes you want to say "Hey, wake up Product Manager!"
They say you can try to wake'm up here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
You don't need to recreate the corridor after changing the code set... You just need to uncheck all the baselines in the corridor properties, apply this setting and then recheck all baselines again.. The corridor will be rebuilt and the changes on your code set will be applied
"You don't need to recreate the corridor after changing the code set... You just need to uncheck all the baselines in the corridor properties, apply this setting and then recheck all baselines again.. The corridor will be rebuilt and the changes on your code set will be applied"
This does not work.... Just tried.
Try this if you have a relatively simple build.
Copy the assembly. Edit the corridor and change to the copy of the assembly. I think if your on the newer versions the targets may hold....big guess here.
John Mayo
Probably a few years late to this discussion, but this one really bugs me. It just makes no sense!
However, I found that instead of unchecking and rechecking the corridor regions, I simply select the corridor in plan, change the Code Set Style to something other than my intended CSS, then change back to the updated CSS.
