Civil 3D Forum
Corridor feature line missing
3 REPLIES 3
JeffPaulsen
4756 Views, 3 Replies
I created an assembly using BasicLaneTransition. When I apply it to my corridor I am not getting a feature line at the crown (center) of the road. I have used this subassembly on several other projects and have not had this issue. The only difference I can think of is that the other projects we started in C3D 2009 and this one is in 2012.
How do I get my feature line to show without adding a marked point?
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
3 REPLIES 3
JeffPaulsen
in reply to: JeffPaulsen
I did a little more digging and it appears that the crown code no longer exists in the subassembly. See attached images from 2009 and 2012. Is there a way to put the codes back?
Jeff Paulsen
sjg
Select your pavement subassemly, and in the autocad properties where you adjust the parameters, turn Crown Point On Inside to on. Add code to code set and I believe that is all you need.
Steve Goessling
Land Consultants
Civil3D 2015
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
JeffPaulsen
in reply to: sjg
Thank you.
Setting "Crown Point on Inside" to Yes did the trick. The codes were added automatically.
I only set it to yes on one side so I did not get two feature lines at the crown.
Jeff Paulsen
Rail Community
