Civil 3D Forum
Corridor back of curb
4 REPLIES 4
bfnaught
3115 Views, 4 Replies
I am new to corridors and am having some trouble with this.  I have an assembly that has a paved roadway, 2' curb and gutter and a sidewalk.  Along the road the curb varies to allow for on street parking.  I have the front and back of sidewalk attached to an alignment, so it is exactly where it needs to be.  I have an alignment that my EOP follows as well, and that seems to be ok. The problem is the back fo curb in the corridor.  Instead of being 2' offset from the EOP, it is shifted 2' perpendicular to the baseline. Please take a look at the attached picture.
I think I can get it done by making each parking "bump out" it's own region using the EOP alignment, but that will take a lot more time and make my file a whole lot bigger. Being a corridor rookie, I am hoping I am just missing something.
I'm using Civil 3D 2013.
Thanks in advance.
Brian
Tags (2)
4 REPLIES 4
in reply to: bfnaught
Yeah, that's how corridors work: everything is always perpendicular to the baseline. There are several things you can do, other than live with it:
1. Use an offset assembly. (See the "Help" files)
2. Dump the bump-out EOP alignment and instead use feature lines to model the bump-outs and add them to your surface. (It works, kind of, but can be cumbersome if you make changes to the corridor proper.)
3. Don't worry much about it and let it ride as you have it now. It will get the flowline and top of curb elevations correct, just not quite where you want them horizontally. There are much worst pitfalls in Civil 3D than that.
When using feature lines for the bump out, they should be located where you want your lip of the C&G.  The assembly attaches at the lip line not the flowline.  That should give you the right horizontal location for the back of curb and flowline.
tcorey
Another option: You could create two different baselines in the same corridor.
First would be a baseline using Centerline alignment and profile. Attach to your region an assembly that has a lane subassy. Set it's width target to the EOP alignment.
That same EOP alignment would be the second baseline (you'll need a profile also), to which you would attach an assembly that has only cgsw and only on one side.
Look on the parameters tab of corridor properties and you'll see where you can Add Baseline. Be sure to add a region to the second baseline because it's not added automatically when you add the new baseline.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
bfnaught
Thanks for the suggestiong.  I looked into offset assemblies and have not been able to get them to work right.  I tried having a separate assembly running down an alignment at the EOP for the curb, and that worked better for the curb, but I couldn't get the sidewalk to properly follow the feature lines. I would just not worry about it, but it looks all jacked up in plan view.  I have moved onto something else right now, but will be getting back onto this soon and will look into having separate alignmets for the centerline of road and the curbs, with maybe the centerline assembly having a sidewalk offset.
Thanks again,
Brian
Rail Community
