Civil 3D Forum
Corridor Surface doesn't fully update?
6 REPLIES 6
3157 Views, 6 Replies
I have a corridor that uses the UrbanSidewalk subassembly along the streets.
During my rough design phase I set the outside boulevard widths to 2.00, and
create a corridor surface using the Top Links as breaklines. I then do my
lot grading, using that surface as a surface pasted into my FG surface. All
of my sideyard swales go up to the edge of the corridor's boulevard, with
the elevation set 0.20 below the corridor surface. Once all of the design is
done, I go back to the corridor and change the boulevard width to 0, thus
forcing those sideyard swales to now go up to the back of walk....this
creates a small depression where we place small drain inlets.
Herein lies my problem, when I change the boulevard width from 2 to 0, the
corridor surface never changes to reflect the 0' width. It's as if the
breaklines that I told the surface to use from the Top links are holding
fast. The ONLY way I have been able to get the surface modeled correctly is
to completely delete the corridor surface and create a new one and recreate
the boundary, which I then need to re-paste and move to the top of the Edits
in my FG surface. Just deleting and re-adding the Top Links from the
corridor surface definition does not solve this.
This seems to be an oversight, that the corridor-created breaklines do not
get revised when the corridor changes, and cannot be edited/deleted by the
user. Am I the only one noticing this? Perhaps I am doing, or not doing,
something that is forcing these breaklines to persist....anyone have any
guidance on that?
Jeff
6 REPLIES 6
It appears that the problem is not from the breaklines, because I now see
that there are no links to create those breaklines from at the outside blvd.
I had created a boundary using the method described by Peter & sinc, which
the surface seems to be holding onto....even after removing the boundary
from the definition.
I have seen this problem in the past and have just worked around it, which
isn't all that hard to do. I'm more curious as to why the corridor surface
does not end up looking like the corridor when there are absolutely no edits
done to the surface, including removal of any boundaries.
Jeff_M
2+ years later and I'm the only one who has responded to this. I can't believe I'm the only one this is happenning to. I now have a detailed corridor model of a multi-family project which, until an hour ago, has been working great. Modifying the corridor via assemblies, regions, profiles, whatever, has been an ongoing process for the past 2 months. Doing the same thing today, and I'm now getting the Surface to only sometimes change with the corridor revisions...and most of those times it is incorrect. It started out as just affecting one baseline, but now others have jumped on the band wagon.
This corridor and surface are important pieces to my plan production sheets which are all labeled (based on a surface this one is pasted into) and ready for submittal. If I can't get this surface to update properly, well, it won't be a good thing.
In this image, I have selected the corridor so it can be seen vs the Tin lines. Note that there is no longer any corridor region along the street going to the right. I removed this regions due to the surface not reflecting a change in the Assembly being used. Yet the surface remains showing as if the original assembly were still in use.
So short of removing the Surface and rebuilding it, any ideas floating around?
Jeff_M, also a frequent Swamper
Jeff_M
in reply to: Jeff_M
You should've tried the SOP, Save, Close, Restart. This appears to have kicked it back into submission.
Oh, this was in 2012, SP1, btw.
wfberry
in reply to: Jeff_M
OK, Jeff, QUIT talking to yourself.  Yesterday thru today I was experiencing a similar situation after I changed to different assemblies, etc.  I am using 2013 and I definitely ALWAYS use the save, close, restart as my first as my first remedy.  I must be in a different zone  because  SOP is not appearing on my screen.
Robot Embarassed
Bill
paul
This just happened to me.  I did an audit to fix the errors, restarted C3D, and rebuilt the corridor and now it works fine.
paul
This happens to me 1 out of 10 times.  Make sure the surface, feature lines, and corridor surface layer is not locked.  Otherwise a restart should fix the problem with the occasional audit.
Rail Community
