Civil 3D Forum
Corridor Surface Problems
5 REPLIES 5
steviek68
519 Views, 5 Replies
I'm having issues with building corridor surfaces (please see attachment). More and more I'm finding parts missing from the triangulation surface. Given it occurs mostly at Junctions I suspect my assemblies may be faulty, but having inspected them i can't find an obvious problem. Can anyone please help?
5 REPLIES 5
neilyj666
in reply to: steviek68
Draw a polyline around and add to the surface as a show boundary - this may not get to the root of the problem (why there are holes) but at least you'll get a surface
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
steviek68
in reply to: neilyj666
Thanks, I had a go at that already which is a decent workaround, but as you say it doesn't quite solve the problem. My gut feeling is that it's an issue with the assembly, perhaps I'll have a closer look when I get a moment.
AllenJessup
I can't say if this is your problem. But I've had similar errors when I had a the curb vertical or undercut. Once I fixed it in the assembly the wholes were gone.
Allen
Allen Jessup
CAD Manager - Designer
steviek68
in reply to: AllenJessup
Had a bash at that but unfortunately it was to no avail. Thanks for the tip though. I may have another attempt with another kerb/curb set just to completely eliminate the possibility.
troma
I had something similar happen when the corridor was set to match existing surface at a set slope from edge of road.  Got everything looking good, then had to update the profile.  Elevations changed, slope matches at a different point.  Suddenly the boundary I had for the surface was wrong, because the matchline moved.  Ended up with missing triangles similar to yours.
I guess this is way too simple a problem that you wouldn't have caught it, sounds like you were already looking into the boundaries....but just adding my twopence worth of thoughts to the discussion.
Mark Green
Working on Civil 3D in Canada
Rail Community
