Any simple suggestion on calculating stripping using a corridor.
All we have is an alignment and a surface. In one region we need to calculate the stripping that is 6m wide x 1m deep.
I used LinkOffsetOnSurface to get the surface elevation on the left and right side.
I then tried using the stripping subassemblies but no luck.
because we have a number of regions and assemblies we would rather use corridors than creating a stripping surface.
Has anyone else tried this or have a suggestion.
Have you tried the stock StrippingTopSoil subassembly?
neilyj (No connection with Autodesk other than using the products in the real world)
