Civil 3D Forum
Corridor Section View - Section View Group Issue
4 REPLIES 4
326 Views, 4 Replies
I found a few issues on here that sounded similar, but not exactly the same, so here we go: I have a users drawing that  seems to have an update issue.  It is a simple 1 block street to which he has made of frequnecy line section edits.  The issue comes with the Section View Groups.  When he creates the section views, only the changes to the left side show up, but not the right.  The surface seems to be correct, but not the corridor section itself.  The sample line is directly over the top of the frequency line (in fact I made a two others on a few feet on either side and modified those as well to make sure the through section was okay), and I have deleted and recreated all the components that would have any affect on this (sample lines, surfaces, boundaries, etc.), but to no avail.
Thanks in advance for any help anyone may be able to offer!
4 REPLIES 4
machadt
Hi Kris,
Could you please load and image so we can see what you are describing?
Tatiana Machado
AEC-ENI Application Engineer
in reply to: machadt
Here you go
machadt
Hi Kris,
Can you upload this drawing?
I will gladly take a look at it.
Tatiana Machado
I have had this same issue. I have the same workflow, and finally figured it out:
1. Don't be in the drawing with the sections while you are modifying the drawing with the corridor, or surfaces, or anything else involved. Strange things happen!
2. I find I have to go to the Sample Line Group properties, go to the Sections tab, delete the Corridor that was modified, then add it back and everything updates properly. It's a bit of a hassle, but it works.
Hope this helps.....
Rail Community
