Like open the Corridor, look athe the Parameters Tab, Rt-Click and Select Copy to clipboard will give the text you see below, is this what you are after?
Name Alignment Profile Assembly Start Station End Station Frequency Target Overrides
Baseline (1) West Virgina - (1) WV PGL (1) WV PGL (1) 10+00.00' 35+65.00' 35+65.00'
Region (1) Region (1) Region (1) Basic 14' lane - (1) 10+00.00' 13+12.37' 25.000'
Region (2) Region (2) Region (2) Basic 14 Lane Transitin - (1) 13+12.37' 22+29.50' 25.000'
Region (3) Region (3) Region (3) Basic With Curb Offsets - (1) 22+29.50' 22+53.28' **Varies...**
Offset Alignment WV RT ep return sw - (1) pgl (1) pgl (1) 22+29.50' 22+54.50' 22+54.50' 22+54.50' 22+54.50'
Offset Alignment WV LT ep return nw - (1) pgl (3) pgl (3) 22+29.50' 22+54.50' 22+54.50' 22+54.50' 22+54.50'
Region (4) Region (4) Region (4) Typ Trans Thru No CG - (1) 22+54.50' 23+09.34' **Varies...**
Region (5) Region (5) Region (5) Basic With Curb Offsets - (1) 23+09.34' 23+35.50' **Varies...**
Offset Alignment WV RT ep return se - (1) pgl(1) pgl(1) 23+09.34' 23+35.50' 23+35.50' 23+35.50' 23+35.50'
Offset Alignment WV LT ep return ne - (1) pgl (2) pgl (2) 23+09.34' 23+35.50' 23+35.50' 23+35.50' 23+35.50'
Region (6) Region (6) Region (6) Basic 14 Lane Transitin - (1) 23+35.50' 28+57.00' 25.000'
Region (7) Region (7) Region (7) Typ Trans No CG Rt - (1) 28+57.00' 29+63.00' 25.000'
Region (8) Region (8) Region (8) Basic 14 Lane Transitin - (1) 29+63.00' 33+55.33' 25.000'
Baseline (2) WV Rt EP - (1) rt ep pgl (4) rt ep pgl (4) 0+00.00' 25+39.91' 25+39.91'
Region (1) Region (1) Region (1) Curb Return RT - (1) 23+55.61' 25+39.50' **Varies...**
Baseline (3) WV LT EP - (1) lt ep pgl(1) lt ep pgl(1) 0+00.00' 25+44.91' 25+44.91'
Region (1) Region (1) Region (1) Curb Return Left - (1) 23+55.61' 25+42.27' **Varies...**
Baseline (4) Knuckle Rt Center- (1) pgl (6) pgl (6) 0+00.00' 15+10.11' 15+10.11'
Region (2) Region (2) Region (2) Typ w Rt Lot Grades - (1) 1+39.48' 6+64.65' **Varies...**
Baseline (5) Knuckle Rt EP - (1) pgl (5) pgl (5) 0+00.00' 14+99.06' 14+99.06'
Region (1) Region (1) Region (1) Curb Return RT - (1) 5+97.89' 14+99.06' **Varies...**
Baseline (6) Knuckle Lt EP - (1) pgl(3) pgl(3) 0+00.00' 13+55.20' 13+55.20'
Region (1) Region (1) Region (1) Curb Return Left - (1) 5+78.28' 13+55.20' **Varies...**
Baseline (7) North - (1) North PGL(1) North PGL(1) 0+00.00' 16+70.11' 16+70.11'
Region (1) Region (1) Region (1) BLT with curb offsets - (1) 0+00.00' 9+99.72' 25.000'
Offset Alignment North rt ep - (1) STD North Ep PGL - [North - (1)] - (6) STD North Ep PGL - [North - (1)] - (6) 0+00.00' 9+99.72' 9+99.72' 9+99.72' 9+99.72'
Offset Alignment North lt ep - (1) STD North Ep PGL - [North - (1)] - (7) STD North Ep PGL - [North - (1)] - (7) 0+00.00' 9+99.72' 9+99.72' 9+99.72' 9+99.72'
Baseline (8) North - (1) North PGL(1) North PGL(1) 0+00.00' 16+70.11' 16+70.11'
Region (1) Region (1) Region (1) BLT with curb offsets - (1) 11+10.59' 16+70.11' 25.000'
Offset Alignment North rt ep - (2) STD North Ep PGL - [North - (1)] - (9) STD North Ep PGL - [North - (1)] - (9) 11+10.59' 16+70.11' 16+70.11' 16+70.11' 16+70.11'
Offset Alignment North lt ep - (2) STD North Ep PGL - [North - (1)] - (8) STD North Ep PGL - [North - (1)] - (8) 11+10.59' 16+70.11' 16+70.11' 16+70.11' 16+70.11'
Baseline (9) Stream - (1) Channel PGL (1) Channel PGL (1) 7+00.00' 33+57.83' 33+57.83'
Region (1) Region (1) Region (1) Channel From Links - (1) 7+00.00' 21+00.53' 15.000'
Baseline (10) Stream - (1) Channel PGL (1) Channel PGL (1) 7+00.00' 33+57.83' 33+57.83'
Region (1) Region (1) Region (1) Channel From Links - (1) 22+12.22' 33+57.83' 25.000'
Baseline (11) Knuckle Lt EP - (1) pgl(3) pgl(3) 0+00.00' 13+55.20' 13+55.20'
Region (1) Region (1) Region (1) Curb Return Left - (1) 0+12.04' 0+40.23' **Varies...**
Region (2) Region (2) Region (2) Curb Return Left - (1) 0+40.23' 0+51.27' **Varies...**
