I have a corridor (see attached) where the ditch is not showing up in some places. Section A-A is correct, then for about 30m no ditch on the left side (section B-B). It's all the same region in the corridor and there's nothing unusual with the target surface in that area. I've adjusted the frequency but that doesn't help. I'm using C3D 2013.
Any help appreciated,
Solved by doben. Go to Solution.
Solved by Neilw_05. Go to Solution.
We need more information. What subassembly are you using for the ditch and daylight?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Looking at the cross sections I see the shoulder in Sect A-A is in cut and in B-B it is in fill. My bet is the assembly is not applying the ditch if the shoulder is in fill.
