I was wonderin if there is a way to create an .asc file of a corridor surface at speciffic intervals. If we wanted to create a point file of the corridor surface at 50' intervals or is the only point option within the toolbax tab of the tool space. I did the tool box option, create csv file of corridor surface, it created somthing in area of 30,000 points for about a mile and a half road.
Solved by jeff_rivers. Go to Solution.
You can Create Points - Surface - On Grid Then export the points.
Other options would be points along alignments.
Would neither of those work?
Conan Witzel
Yeah, that lokks like it will be the ticket. I do not get to mess with corridors as often as I would like, should be interesting to see what it comes up with.
Thanks, Lang
