I could've sworn this worked correctly at one time, but I sure canot get it to do so now. I have a small roadway widening which includes a parking bay and a sidewalk that varies in location, elevation, & width. Here are the 3 subassemblies used to create the corridor. The top is the normal half section (we are widening just the left side of the road), the center one is for the elevated sidewalk, and the lower one is for the parking bay region so it includes an Offset Assembly.
Everything works as desired, with the lone exception of the lack of featurelines being created for the Offset Assembly objects. All the curb & sidewalk f/l's are fine for the other regions using the 2 other assemblies, but I get none with the Offset Assy. Is this normal and my memory has failed me once again? Or should this be working and I've somehow mucked it up?
Thanks for looking, no offense taken. I'm looking for any suggestions that might help. I don't think they are off, as they are defined to use the same style as those that are showing and the curb/sidewalk subassemblies are identical (code-wise).
I have found the same behavior with offset assemblies in versions up to 2011. (Have not tried this yet in 2012). This becomes a problem when building corridor surfaces from feature lines. You have to build the surface from links.
Because of this, I rarely use offset assemblies. I will model the offset with a generic offset and elevation link, with the omit property set to 'yes'. It will create all links radial to the the baseline alignment, so you wont get the curb and sidewalk perpendicular to the edge of pavement or flowline.
That's messed up. I created a new dwg, made a new alignment, profile, corridor, offset etc. It worked perfectly. I XML'd your stuff into mine and it did not work.
